nah, wasn't the same one. That's Sam (SAWAKITA)... this one was about 8:40 in St Leonards and don't think the driver was Asian.
hmm was it?
plates where like.... ATH something.....
hmmm the r33 s2 white was behind me at the lights, I was waiting for them to flash me or something, dunno.. I have a SAU sticker on the back.. hmmm...... :confused:
Saw a couple of Skylines tonight
1. Sawakita on Epping Road near Epping station
2. Had a nice run with JDM-32R white R32 GTR, a WRX and a Soarer down Gore Hill end of Epping Road.
3. GTR-80Y in the city, burgundy R33 GTS-T.
Had to overtake JEF-25T on the inside this morning in the peakhour traffic approaching Cumberland Highway. I must have got all the good gaps because he dissapeared shortly after.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
