really?! thanks for the warning  :O  i just got the car a week ago hopefully mine won't end up like yours  :D
Actually, if you want to go towards nulla/sutherland area, take the bypass!!! Dont go through Menai rd (Bangor)... Faaarrrkskies, I have to go that way this morning... GRRR!
You will prob see my line floating around menai/bangor/sutherland shire area, currently is white with big white rims....
Theres a few other skylines in our area too, but gotta love the school kiddies in their VL's/VN's and VS's thinking their king of shite!
yea theres a red one owned by a guy next street and theres also a burgundy one i see from time to time around here :(
Spotted GTR80Y on Falcon St near Crows Nest, had a chat at the lights and had a bit off a run. :(
spotted him on the pacific highway at about pymble aswell!
wouldn't have seen me, I was in the proton!
PROTON POWWWWWWARRRRR
yea theres a red one owned by a guy next street and theres also a burgundy one i see from time to time around here  :ph34r:
Guy round the corner from me has a black 32, another guy near the new estate has a GTR and stagea, and theres also another 33 floating around which is black...
By the way, what colour is your line? Series 2 or 1? Just so I can look out for ya!
a black stock series1 :ph34r: i'm getting SAU club stickers on the front and rear window so it will be easy to spot me!
Spotted GTR80Y on Falcon St near Crows Nest, had a chat at the lights and had a bit off a run. :D
Hey dude, u another northy too? HArd to keep the car straight when 1 rear wheel is the spacesaver hahaha.
Liz: Proton ;) ?? Stil parking in northpoint? Was working the other day, didn't see you.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
