spotted a white 33 s2 p plate at hume hwy turning into bankstown today 6pm, also a silver 34 near bankstown shopping centre around the same time, i was in my stock 33 black with stickers down the door
1 question.
if its stock.
why the hell does it have a shopping list?
or are the different stickers?
Saw a gunmetal R-32 GT-R on Chruch St, Parra this afternoon (Thursday) as I was heading home from work - this was about 5.15pm.
Plates were AUB-88T or something similar...
I was in my aqua Corolla.
1 question.
if its stock.
performancewise its currently a stock car, but looking to mod the car slowly after i get paid from work
spotted atu something.. a purple 33 gtr partked in the city..
also spotted SAWAKITA in his new teggy type s!!!! :wacko: i try and look for you when i'm around your house, but never see you!! the one day i don't really look, you're in front of me! lol!!!!!! :wavey: the teggy looks good! ;) you've already got an exhaust!!! :(
AJR 05M at northmead area around 4:20pm gtst r33 s2, white. with nice looking white rims. apart from that looked stock. still looked sxc :) come to think of it.. its pritty close to what mine looks like :(
saw a bright red r32 gtr parked at the entrance to the old pacific highway in berowra on last wednesday night
saw a cop car parked behind the red GTR with the lights flashing too...
i hope the gtr driver didn't get done too hard
but that red GTR was NICE!!
Spotted a Purple R33 driving down my st, plates were DRIF7D I think or somthing simillar
Spotted this car today (yesterday) also, just can't recall at this point in time.
OMG OMG OMG
I met Paul and Stace At Jamboree
I WANT TWO.06l
GIMME GIMME :lol:
And Adrian 2RISMO
Going back there today i want to see it bust into the 9's :P
Edited by Slide
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
