ya took ya time posting it up :P
Danny is on here.. Drives a White r32 GTR
Shaolin, thats who I was talking about before, drive a silver Supra.
Does he have white impuls on it, coz i see this one thats always parked near my house, he works at the toyota????
yeh i was busy trying to fix the water in my boot problem, which i did, my rear tail light seal was leaking, fixed that....
spotted DHC, on vic road at bout 5:20pm, heading towards gladesville.... once again nice ride mate, i dunno if u saw me i was heading the other way..
thanks mate.
Now that you mention it I think I did see a white 33 going in the other direction...but I saw more than one white sky that day so yeah didnt know it was you.
hahaha looks like that car got sold to a sydney sider...
It was for sale not long ago....orginally from queensland.
This one?
The brother of one of the people at OCAU owns it.
Went down to Forster on the weekend for my cousins wedding.
On friday, saw a wine red R33 GTS-T in grafton, S2 wing and flame graphics down the side.. thats all i saw.
Saw a silver R33 GTR somewhere along the way between grafton and forster (cant remember where) lol..
Friday night saw a wine red R32 GTS-t driving across the Forster-Tuncurry bridge, think it was doing laps. Number plates something-15P. Saw it again on Saturday driving in Forster.
Saturday saw a wine red R33 GTS-T driving in Tuncurry, damaged front bar.
Also saw a gunmetal R32, looked like it was a GTR (wide rear fenders etc) but dont think it had a badge on the back, it was heading towards Forster from Pacific Palms direction.
Today (sunday) around lunchtime saw a charcoal R33 GTS-T with BEN-something numberplates, FMIC, 18s (i think) with green P's inside window, was near shopping centre/KFC.
Are there even any members on here from Forster area? I would've waved but I didn't take my skyline down..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
