spotted an attractive young lady in a S2 on the m2 when i was coming back from today.
Driving next to her for like 30 seconds, no look from her or her equally attractive friend. Just not the skyline way. :D
Oh, and I couldn't make it too obvious that I was trying to get their attention, cos of my passenger.
But a great day today anyway :D
spotted  white R32 GTR with R34 GTR rims..
@ victoria road ermington on the way to parra
and had a quirt with a maroon R32 gtst with TD04 and external wastergate
sounds crazy also a SAU member
yeh had a dash with a guy in a white 32GTR with 34 GTR rims, the thing was quick had a chat and he said it had 350awkw.... might of been the same one, he lives in the parra area... was he a lebo?
lol yeap that's him..
i had a bit of a run..
but up till 3 rd gear same length..
he wasnt gaining i wasnt pulling..
then is stopped :D
nice nice, so i take it ur car isnt stock???? LOL
wat u got done to urs? if u dont mind me asking....
spotted GTR.0*R
best r34 GTR i have seen so far!!
seemed to be same colour as a NUR??
lowered and sounding beautiful
i was weaving traffic to catch up behind then at grand parade under the tunnel you gave it a nice squirt....awsome..
spotted GTR.0*R
The silver 34. GTR-00R. IF thats the one u spotted its an awesome car.
The guy who imported mine Kris over near Moorebank was doing some work on it when i fixed up mine for compliance. New engine and massive set of brakes were going into it. Gave it a squirt when he left.... Never seen so much smoke pour off 4 tyres in my life... The poor pirelli's bushfired the street. Then i got in my pissy r33 and drove off like it was a barina. :(
Spotted RUF GTR in castle hill. hung out the window and waved but looked like an idiot cos he didnt spot me :(
thats the one....
this is gtr00r.
nice car the owner is the brother of cyber motorsport. good guy.
has a set of n1 turbos because when they where doing some work on it the owner forgot to take out all the rages killed the turbos.
this is gtr00r.
Yep that fence looks familar... Think mine sat in that exact spot! Nice group of guys there....They own a big ass dog as well. They helped build a rear wheel drive conversion on a GTI-R. They call themselves the Jap Boyz....
Wasn't in my R32 so I didn't wave, flash as you would have thought i was a nutter!
You were stopped at the lights at the intersection of Kenthurst rd.  See you round a bit actually :(
Ahh ok no worries.. Yeh im around that area pretty often. I live in Castle Hill, old man lives in Glenhaven and mates live at Dural, Arcadia, Hornsby etc :(
Was driving around Dubbo today (where i live :P ) in my 32 and i saw another 32 with a SAU sticker. HCR320. Not a local i know that for sure. Nice to see another 32 out this way though!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
