hey silver was I parked or cruising around ??
You should have seen slim, and dave and mona, liz as well....
I was at shelbourne for a mates bday.....thent met up with them later.....
mar55s......hehe...I agree with your IMPUL statement in your sig :P
just u, cruising near city hotel
Hahahaha! hey mass.. we were just getting some take away coffee.. then realized it was a parking spot so just stayed there and finished drinking.. saw a black 34 with wot i think was a tommy Kaira kit... very nois..
BTW.. wots that front bar Mass?? I Like. :P
lol dude i get that heaps i dont know exactly as it came with the car, but i havent seen it anywhere... it doesnt have a name on it, i think it may be a custom job, but it looks similar to some of the trust bars
If it was a dark green Stagea, then it was most likely me!
Whereabouts in Parra were you and what time was this?
I think I saw you on Old Northern Rd a couple of days ago.. I was in the White 33 that flashed you going the other way. Either it was you or another green stagea! :P
if anyone saw my car this morning between 1:30 and 7:00 am please call me immediately (0422 646 173)
:) Aww nooo! I hope the bastards who stole it die a painful, horrible death - and burn in hell forever..
Sorry to hear your loss mate ;):P
DJ - where from in Hornsby mate?(understand if you dont want to post it)
il lkeep an eye out
Sorry to hear your loss :D hope the muthafockers rott in hell slowly.
i think I saw Kels black 350.. does it have skylinesaustralia.com sticker across the front window?
LOL- the Zed does have the shticker. It gets lots of funny looks, but we are an owner *and* enthusiasts club right?!
Spotted lots of lines out over the weekend but I'm hopeless at remembering plates. Now I just wave at everyone in case they're an SAU-er :P
ive spotted so many skylines over the weekend.... wasnt in my car though... seen a couple of nice ones down south in the last couple of nights......
dont think any were you regular broad minded persons :P
I think I saw you on Old Northern Rd a couple of days ago.. I was in the White 33 that flashed you going the other way. Either it was you or another green stagea! ;)
Hmmm, Old Northern Road is fairly close to home, but I can't remember when I used it last... Was I heading towards or away from Castle Hill?
:P:P
I swear it wasnt you or duncan driving though. anyone else been driving your car?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
