Spotted a black R32 GTR with bling bling 18"s and a FMIC on James Ruse Drive at about 5:45...
aaaand spotted a white S2 R33 with FMIC+blue piping - Plates AJT-XXX? Crusing past castle towers shopping centre a short time ago...
Also a dark blue S1 R33 Waiting at the lights at Old Northern Rd/Castle Hill Rd a short time ago.. Cant remember the plates - XXX-55S or something. *Beep Beep* :D
spotted a 33 bluey purple sky on beecroft road!! i beeped as i was turning onto the m2... was a chick driver! :wavey:
spotted a dark 34 plates - aqn88s.. parked at one of my carpark places in the city..
and this morning spotted black 32 - ai 33 xx parked at another car park in the city :D
for the past month ive been waving to a marone r32 (no wing) that passes me on old northen road on my way to maroota, they never wave back.
andy the same thing, but with another marone 32 (has a wing this time) on glenhaven road.. he never waves too
whats with all the non wavers now. i feel like the bigest tool with my arm waving out the window and they just give me a weird look, lol :lol:
Saw a white 33 gtr last night, around wiley park king georges road. Cant remember the plates. But he attempted to race a cayenne turbo and didnt really beat it :s
Upgrade your turbos and you'll go a bit quicker. PS you blew a whole heap of black smoke out the back
Spotted ecl in Chatswood n the City last night... was tailing him ALL night long ;)
Spotted stock white R34 with a T-Wing in Chatswood around 730pm
Spotted bright organge R33 on George Street around 1130pm
Spotted about a million white R33s on George Street between 1130pm and 0230am :P
Highlights of the night, seeing MZVTEC and a Magna almost taking out a cabby whilst on boost :rofl:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
