Fri arvo?
Spotted by SW20 again? You must be too stealthy!
Not long after that I spotted a 4 skyline convoy (had one black 34GTT) and another trailing 34GTT with P plates going west on victoria rd between powerplay and the gladesville bridge. Someone honked as they pass me but i was stuck behind a Tourak tractor and didn't react fast enough after seeing the first skyline! I pressed my horn late too but it didn't work. AAnyone know where to get a spare horn button? Mine's smashed mine to bits honking someone.
T
Yep, the black Honda Accor Euro is Stealth++
also JR34GT yellow R34 GTT with the Nissan Aero kit on Lane Cove Rd near the Comenarra Parkway
i think i might work with whoever owns that car, its parked outside my work everyday, but i have no idea who owns it.
Spotted CYIFLY near Auburn?
MARSS in George Street.
A Gold/Yellow R33 with a black wing wearing a SAU sticker on the quatre panel going through Chittaway.
A few grey R32's in the city. One pssching past a nice WRX.
Blacktown @ Midnight (Near Blacktown Hospo)
Black r32 GTS-T Sexy with bov.. not sure on numberplate
White r33 GTS-T White with bov.. RB-1337 Red Plates
Silver r33 GTS-T Tried to race us lol... 4KRUZIN
4kruzn was on a commonwhore with air bags
(glad i didnt buy it)
did CYIFLY used be on a green sprinter like 10yrs ago.
OFD-14L do you come on here?
Spotted TRD-33Y on cleveland street around 7ish on saturday, damn that traffic was bad.
Spotted TURBOS at double bay around 1.30am sunday with a ridiculously loud exhuast.
and two girls in a grey R32 GTST on cleveland street 2.30am ish dancing and singing in the car.
BTW, I was in a white R32 GTR ATI-33A
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
