Spotted a silver r33 crossing over epping rd with SAU sticker on the rear quater window
Possibly me! Intersection of Epping Road and Centennial Avenue? Was on my way to pick up a new Nismo knob! :D
MSP-25T & DHC on Victoria Rd about 15 mins ago :laugh:
hahaha dammit tosh I didnt see ya....
BUT I did spot mass near the Millers self storage on vic rd...Gladesville.
You see mass as well ??
Funny thing is....she saw you and I didnt but I saw mass and she completley missed him. >_<
hahaha.. i know!!! how weird is that thomas!!!!
and tosh.. sif have a ute with plates R34 GTR >_<
and can't believe you saw us on the anzac bridge!!!! dave would have been behind me! and ms would have been chasing greg down on his sexy honda cbr!! :drool:
Yesturday evening - spotted a maroon 33 gtst and a black 32 gtst on pacific highway near the servo's at berowra - heading north, gave a toot and a wave, got a wave back
spotted exh-45t stuck in traffic bout 6:15, i was going opposite direction.... gave a half wave! got full one back! Champion
Neat looking car!
Yah that was me :P
Thanks mate.. yours looking great too! I didnt catch your plates in time!
Also saw SHRUGZ (Wine Red R33 S2) and HUH-000 (White R33 S2) --- Waved, but nothing in return :D
