spotted-
eurospecs' mum's car at my house last night...
wont bother making two posts about spotting her, as i know she'll be back tonight. maybe tomorrow night as well, if she gets time off work.
let me know eurospec, or i'll make other plans :D
wtf
what a lying bitch! she told me she was sick... u're dead v_twin! :thumbsup:
Did you see an L plater? That was me
haha yes I did, so it was before dropping me home. I thought it was a bit strange seeing a l plater out heaps late
should have recognised you from your picture :thumbsup:
you looked a little freaked out when we drove past though
or you looked like you wanted to check out the car, but you wanted to watch the road lol
Guest Xinhua
hehe you saw my face? I was next to my father coming home from cinemas. giving him a lecture about skylines, then there was miss turbo and i was like wait a sec, i know that car..
lol it was at the part where the road curves like shit, i was checking out the car and then the road came along :(
Spotted Mass_iv at Northern Beaches Performance last week getting some work done...
Spotted Lingeringsoul at Northern Beaches Performance yesterday getting a FMIC, BOV and SAFC done...
Spotted ZIL32A at Northern Beaches Performance yesterday getting some polishing work done...
Spotted SATANIC at Northern Beaches Performance getting stripped down for more work~
All looking good boys!
spotted tolga on pacific hwy :) i love the purple.. hahaha.. sexually frustrated purple :(
hey.. the car gets plenty of loving and is not frustrated at all.
Gave it some loving on Sunday. washed it good!!!
The paint even smells nice..
gotta love zymol car polish.. smells like coconuts!!!
Car is at NBP stripped apart for more goodies...
I'll send you some pics later, got to get the other mechanicals sorted first. Wouldn't want to have my new dash scratched now would I?
Spotted some stuff over the weekend.
"...-641" somewhere .. cant remember :ermm:
ATT 7ID orange 32.. Nice paint and kit but it was lookin like it was gettin stripped in a garage, I won't say where incase it's legit cos I don't want to advertise it :D
