Spoted an R32 on moore oxley road tonight ctown about 9:15, then a 33 on the same road further up at a set of lights opposite me. Gave a wave but got the usual dumb founded look in reply.
and spotted a maroon r33 at ctown bowling carpark tonight.
Spotted a silly Silver R33 S2 driving down sussex street around 3am Saturday with its right indicators flashing right but not turning, with number plates MAR55S. Anyone here?
lolz :P silly Marsss. :( Prolly had your latino music on too loud.
hehehehehe :P we were driving down that rd between your work and the station.. and i was looking across to see if i could see you, instead i saw your panda 33 peaking out!! awwwww :)
omg sif say I drive a 33..
On Epping Road tonight spotted black R33 JDM-33R and waved but driver just deathstared me.
Hey Wink...That was me. I tried to waive but was in the middle of an argument with the missus. Sorry mate. (I think I managed a thumbs up ;) )
Yes I thought it was you but I wasn't sure cos of your new plates!
And dont' worry I hate it too when domestics get in the way of a good wave or wave-back! :)
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
