Spotted a silver R34 GTt last night turning onto Parra Rd heading West-bound @ around 11.30pm, but I saw it too late to check plates, wave/beep, or even check if it was a 2-door or 4-door.
i spotted and heard mass iv ,did u c me?
hey man yeh spotted ya, u shud of came and said hi, i was standing with a mate talking bout his 200sx he is selling it :D nice ride dude love ur tail lights.... did u like the sound of my car???? lol i heard u trash it to make those lights, i had to do the same :nuke:
Edited by mass_iv
Note to all, if you were in the city last night and got told to do a burnout by a drunken moron, that was me, every skyline etc i ripped into and tried to get a show. Another Note to all, you are all weak sauces and no one bagged it up!
Spotted alot of 33s in city last night
smokey in coogee today struggling for traction you hoon!
ummmm thats all i can remember after last night
haha fag, was that you at the rocks? They all did it too :nuke:...
should of came to stay hi.
Old bluebird, sitting on the side of the freeway yesterday near kembla grange with the driver leaning on the armco- and massive hole in the shattered back window of the car, with lotsa little cubes of glass on the ground behind it.
NFI what happened, but it stuck in the 'ol memory :)
haha fag, was that you at the rocks? They all did it too :unsure:...
at the rocks? nah wasnt at the usual spot in the rocks, the furthest i went was the pubs at the end of george st just before circular quay, i was stumbling around with alot of mates pub hopping and making lots of noise :P
comin home saw a burgundy r33, exhaust fmic, red a white plates i cant member but lol.
gave u the thumbs up got a wave back, had to turn off at toongabbie rd.
loving the colour
cheers
Luke
Spotted HUH-000 again today in West Pennant hills (White R33).. I finally figured out what the number plates mean!!
When you flash your lights or wave at the guy, he goes "HUH??" and stares at you blankly!! :)
It's another GTR Badge wearing GTS-T too :laugh:
Someone should start a hall of shame spotted thread!!
hahaha thats a mad plate ms :ninja:
spotted a yellow s15 today in top ryde plates were OMGS15 lol
also spotted gunmetal r33 with the plates JDM-33R and a powerplay sticker it was at top ryde shopping center car park... i was in the red supra ;)... not sure who it is but iv seen it heaps :rofl:
Edited by mass_iv
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
