Saw a blur of white lightning (read 34 four door) over Woronora Bridge yesterday morning.
So quick must be abobob.
No fair, I only put it in neutral and float down the hill. :) Sorry I missed you Drew.
I've actually waved and got a few waves back lately but forgot them all. I'm a space cadet. Training starts Tuesday.
Spotted a R32 - looks like it was painted in the Midnight Purple.. at berowra last night at about 5.30pm.. he was heading down to do stage 1 of the old pac by the looks of it...
Spotted JDM-33R on Delhi Road for like the millionth time
Hello again. I tried to flash and wave at the same time as having a ciggarette but it just went all spastic
You wont be spotting JDM33R for much longer. The line is up for sale or swap for a Stagea
Planning for a family already!? :)
nah..it's for a super secret small business I'm trying to put together. I'll post details as soon as the idea starts becoming reality. I'm sure it's a service that alot of you could use :(:):wave:
thats prob selwyn his not on sau
Spotted:
ASY28G dark purple R32 with green P plate on Pac Hwy around Wahroonga at about 12.30am - waved and got a wave back! :)
AQO61R white R33 with CF inserts on GTR wing on F3 around Asquith? (northbound) about 12.45am - waved but nothin back..... :laugh:
The Stagea is great! I have absolutely no regrets, and can't see myself in another car for quite a few years if ever I decide to change. If anything, I'll probably keep this car and buy another. It's great to own a car that's decently quick, practical, and isn't cop or thief bait.
Mine's a series 1 with manual conversion (using a 32 GT-R box), and there's only three things I dislike about it: weight (roughly 200kgs more than an R33); the clutch (if you've ever driven with a heavy button clutch, you'll know what I mean); and the fuel consumption (which I hope to sort with a PFC and tune). I bought it as it is now, the only thing I've done is replace a turbo - still a standard one, but off an s1 R33. The s1 Stagea uses an s2 R33 engine, and the s2 Stagea uses the Neo RB25DET. More info here, if you haven't already seen it!
My exhaust is loud too - 3" from the cat converter back, with a cannon - but I'm getting used to it (finally, after a year!) and I think it's actually getting quieter some how. Even my old man commented on this yesterday...
Can I suggest JDM-34C as plates? lol
:laugh:
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
