NEXTME
edited by Col-GTSX
Well if you want to end up in jail or worse kill yourself and others race on the streets . We wonder why cops pull skyline drivers over all the time??? A few bad apples and everyone suffers..
NEXTME
edited by Col-GTSX
oh dear :woot:
Spotted a whole heap of skylines and a stagea looking confused last night at thornleigh macca's. I didn't know there was a skyline cruise on last night, i was there with a couple of MR2 friends.
*insert tosh joke here*
Liz-Alex really did blow his engine.....not every engine swap/build takes as long as Steves lol
This is the spotted Page not any other thank u...
then y are u not posting anything bout someone been spotted...
spotted alot of fellow sau's at dinner last night
spotted the MR2 groups too.................nice cars. where were you guys headed?
We just went to Newport via mccarr's creek rd and got some pizza. Saw a few skylines up there, and heaps of commodores and falcons.
spotted quite a few at dinner and terrigal and everywhere,
mikie and myself also spotted bout 5 180's and a sprinter at brooklyn on old pac - 90% on plates - gave em a friendly toot but got death stares back - wtf?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
