Spotted
Smasha
N1R33GTR
Smokey
craved and Mel
miss turbo
Abobob
Liz
Mona
Shif_tea and his siter
t04 GTR PICKING UP A RANDOM CHICK~!!! :happy: go dave!!
Sh@un
Shaolin and his sister and her frriend
hey, thats me! lol, i wish i didnt have the sikton plates =P
Spotted you as well I was passenger in FEAR
What setup you running now?? I haven't seen your car around since it was dark green and Steve owned it.
Saw a tone of Skylines on the city tonight, mainly R33's, But there was a R32 with vinyls on the side at the rocks that was following me for a bit!
-Josh
Yep saw that.. we were in the XR8.. so many grose groseeeee 33's I was about to puke..
Hey Ryan
just got a standard RB25 runnin 10pound. other than that completely stock engine wise. lol, its no where near as good as what steve used to have in it.....
Manveer
