spotted a blue 34 as i was coming onto Ryde road in pymble in the wet last night in a completely straight and uniform motion... anyone who says otherwise is a liar :stupid:
also saw a pretty nice silver 33 parked outside the post office there newr the shell, which was where i was going... to get petrol and stuff... cause thats what they sell there...
WHO ARE YOU SILVER 33?! it looked familiar...
spotted dave (TO4GTR) on mona vale rd last night, spotted yellow R34 really nice and clean car, with JR 34 GT plates, you on here?
sure was yellow?
swear i see that car all the time at towers but it was black?
same plates im pretty sure lol
If you talking about Penrith, I'm the R34 :bunny: . That silver v35 is awesome my dad almost bought one but got a 350z instead.
Which one are you? I often see a white & maroon R33's in addition to the V35
kool,yep Penrith,mines a black 32gtst with fat 18's but dont drive that much & not working at penrith anymore.
also i think it was yesterday spotted a Stagea on the grt wstrn outfront of the car yards at kingswood #plate EGA-41T
sure was yellow?
as yellow as a canary lol, cause i sat behind him for like 20mins along lanecove rd
spotted a black r34 gt infront of westpoint blacktown
a white 34 gtt with carbon fibre hood, front bumper and bonnet air vents,
a purple 33 + a white 32 gtr plated "AN I4 ZE" in norwest fitness first carpark
and also a silver s2 33 with fmic turning out glenwood got a look lol
spotted ethooolll this morning on beecroft road.. also had someone in a silver 34, 4 door (?????) wave to me on beecroft rd.. he was going in the opp direction... i'm sure i saw an sau sticker!
Might be Drew aka lanky71
He's in Epping
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
