Spotted a white R34 GTR M-Spec in Sydney somewhere (I don't go to Syd much if you can't tell). Had a very yellow rear bar.
I was in my mates green magna
Spotted a very nice R32 GTR (i forget plates) in WSID carpark
Spotted more R32's in the carpark.
Spotted a few series 1 R33's running at WSID
Spotted NE-33-XT at WSID
Also spotted TIM in the MX-5 running a few times, and ONN-20S
perhaps one was me :D dark blue 32 gtr
LOL spotted that V8HNTR at liverpool KKs too.
V8HNTR is always across the road from my place in kellyville....
i wish i was lucky enough to get spotted..anyone seen a dark blue r32 4 door with red plates NG-0387 in the hills area? Cos thats me!
Edited by royalt
:P that hurt marsss
Dude... we're in the same boat here... so to speak...
I haven't been spotted in yonks... oh except for the other night..... and last week.... i found that "driving" my car gets results..
anyhoo.. spotted a white 34 in the airport tunnel today with Mine's stickers on it.. not sure if it was a gtr although the plates were GTR something something..
hahaha... you prick.
I'm sure I spotted Liz the other day, in her sexy little red thing :)
oioioi! with comments like that, people are gonna start talking!!! lol
yeah it was me, I couldn't see through the rear window clearly enough to notice it was you!!! :P
No-one spots me either, i see heaps of Skylines on the way to work and back and post it but they must not be part of SAU forum or they just too lazy!!!! =( havent been spotted once in the 2months ive owned the car!!
