At Mount Colah just now, saw tyre trails off the lights that went across both lanes, smelt burning rubber and spotted a gunmetal grey R32 parked at the rubber duckies. Mate if you weren't avoiding an accident or some other legitimate reason you're a bloody idiot, I hope you're not in SAU.
last Nyte i was in George st City
spotted a fair few skylines, White r33 with Black bonnet, a Dark purple r33 gt-s very very niceee ... And Another one number plates Qatar very nice too.a bacl r33 gts-s s1 on stokies very nice.. Unfortunately NO GTR'S But...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
