thats the one, i was under my car heard turbo jumped up and saw that drive past
I didn't see you there dude , I was there to inspect a car for a friend in Coachwood place, he was in a liberty .
Spotted Abo bob on victoria rd gladesville near the ryde aquatic centre around 7ish this evening
And you probably would have seen Chubbs in the grandpa spec 31 behind me. Must have been a bit later than that though. That's also about where the lancer tried to take me out. Do you drive a lancer in your spare time... :thumbsup:
lol! you snooze, you lose :P
you end up buying the helmet? :)
hahaha. No didn't end up getting a helmet after realising there wasn't going to be a discount. :( I'm going to head out to Parra and see what they have.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
