who the f*k is Jason?
JET-32R was owned and built by a guy named Lucas
Yes it was :P
JETR32 on here (Jason) did not sell his car i believe... or did he?
Also spotted Anna this morn on the way to work... NIGHT RIDER! :D (during the day time)
Also spotted Anna this morn on the way to work... NIGHT RIDER! :P (during the day time)
:D ... for the last time... its not Kit... its not night rider... its the Black Bish No 2!!!
btw was half asleep and didn't see you this morning... assuming it was in the same spot as usual???
spotted wink parked yesterday at manly and also a silver r33 series 2 parked at manly aswell number plate ***33r
both nice looking cars
Yay. Thanks!
Finding street parking in Manly beach on a sunny Sunday afternoon is bloody hard. So lucky I got that spot - and the Skyline wouldn't have fit in there either! :D
Spotted in Chatswood yesterday "DR SKY" white R34 coupe.
LOL guy obviously abused the shit out of it because that car has been going for the past 2-3 years without even the slightest of issues
i used to drive it all the time and it was great
I'm always seeing GTR-97V around Dural in the arvo's. It's a nice, clean white one. Not sure of the model tho..
And the other day spotted a nice pearl purple 'Line out at Bunnings Dural, it looked mean
Obviously :laugh:
I mean everybody knows that it takes an entire 3 days to kill the big end bearings on an RB26.
Your mate got the better deal, mine now has to try to find the money for a rebuild.
I havent actually had a chance to trash it yet wanted new tyres and brakes before I did that
just driving home casually last night and it starts dropping oil pressure then it started the big end knock :laugh:
LMAO what a joke
funny how people who i know saw you thrashing the arse out of it
but it conveniently dropped oil pressure while "casually" driving home
really? I was just casually driving it home at the time, but regardless whats done is done, I bought the car now its my problem
and my idea of thrashing is more than just a squirt every now and then which is all ive had a chance to do...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
