Spotted this evening around 6pm on York St in the city I think it is? A white R33 with carbon fibre boot and stealth spoiler and blueish looking graphics or writing on the sides, I was on the Anzac Bridge so you probably didn't see me.
Spotted a silver V35??? with SAU stickers at the M4 homebush off ramp early morning around friday last week. My girlfriend also saw this car yesterday on her way home from the city.
spotted a couple of R32's, S15, couple of S13's, buzzboxes and some random V8's all on the F6 at around 12pm last nite....looked like they had come back from doing a nasho run or something and i just ended up in the middle of they're cruise, was all very spontaneous and random.
Keep spotting a Silver R34 I believe its a GT model as it has the GT rims.
I think a asian girl drives it, may I add extremely attractive when I saw her one morning.
Dont know who you are, but often see your pride and joy. Hope your on here!
Oh I drive the R34 Black with Impul rims. Oh in chatswood :(
See you round.
There was a meet at P6 last night Sam, was probably that.
spotted the sexiest purple 32 in north rocks today.. man that color is HOT!!!! sorry i didn't let you in.. was so damn busy drooling!
also spotted a purple 33 at the bp on seven hills rd.. was a purple evening!!! would have been complete if i'd seen your car, -MASS- :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
