lol and I thought the race car was low key. was off to hills to get it tuned.
that traffic was shithouse I could not do that every night. especially not with a race clutch, straight thru zorst, race brake pads (ie no braking when cold), no radio, no demister in the rain.
Were you in the Z? I didn't notice it :P
nah the 33..... i was crawling through the etag thing to get onto the M2 and caught the yellow beast out the corner of my eye...
Yeah im usually going in the opposite direction but tonight was long weekend crazy traffic... never normally that bad!!
Spotted white 33 gtst on luxford rd mt druitt round 930 this morning.
Spotted myself driving after 9 months worth of suspensions finally came to an end today :P , must remember to be careful coming off suspension in double demerit times.
Spotted ROB 32T I think it was in seven hills today.. awwwwwwwwwwwwwesome looking car, I think it was a bit laggy though or it was just double demerits lol
spotted an older dude in a silver R32 GTR in seven hills around 5pm too.. then another one on seven hills road parked..
spotted a few SAU'ers at the northern last night .... Steveo, Ando, Adam, Carly, Corinne, Dave, Georgie, Nick, Smoky.... ummmz did I forget anyone????
Didn't forget me....as I wasnt there :( d'oh
Spotted my car in the garage when it should be ON the road and racing this weekend :P
Didn't forget me....as I wasnt there :) d'oh
Spotted my car in the garage when it should be ON the road and racing this weekend :)
Awwwww tried calling you to make you feel included... :P
I think I was a bad influence on Georgie.... she was "k im going home" and I went "just one more drink" :)
several times this sequence occured.... :(:)
Spotted coppers following me home ... again, :(
was on the driveway waiting 4 the garage door to open to sufficient height so I can get in
wankers stopped on the road in front of me driveway and shone some bloody torch at me car
can I make a complaint for stalking?
how was wakie yesterday? sounds like it is very wet for the state supersprint today
Was a fantastic day - sunny and cool, about 21. It was my first time out at Wakie and first time in the GTR all out on the track. I think it would have been better if my front transfer case was actually working as I was oversteer city everywhere.
I managed consistent 1:20's with a 1:17, 1:18, 1:19 while chasing down the Evo and Breakmaster. That was on my street tyres that are just regular 'ol Toyo Transas. Next time I'll bring out the slicks.
Now my pads are a bit glazed so have to tear 'em down to scuff them up. Better get some track pads too.
Great day!
(although I had to vacuum out the car from all the grass and dust, I went off about 5 times :blush: my bad!)
Edited by Pezhead
OH MY GOD! OH MY GOD! I GOT SPOTTED :PBJ:
Thanks man :blush: wanna buy it :blush:
I think it was a bit of both (lag and double demerits)
I saw the plates and figured it was you slim, nice car dude.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
