spotted a wine red R32 GTR today at kellyville post office today..plates were MEL-*** i was gonna come say g'day but i didn't see you get out of the car and i went into the newsagency..then you left :)
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :D
Also spotted R33GTR (Mitch) at the RTA on my way to work... Whatchu doin there?!
Drove alongside a maroon R33 with nice white rims on Old Northern Rd last night, about 7:45? Wheels looked a bit like Enkeis, but couldn't tell while moving. Dude with a cap on was driving. I was in the black R32 if they're on here and wondering.
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :(
lol, tell your mum i said sorry :D
yeah
cbf turning a big ass 4wd lol
spotted a red R31 sedan on sunnyholt rd, BB... something :devil:
i keep driving past a black r32 through the back of rosebery, parked close by to the mitre 10 that burnt down a couple of months ago
it's a really clean and well modified gtst one of the best ive seen, and it's up for sale, if it's anyone on here good work and best of luck
with the sale.
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :ninja:
handing in notice of disposal. where bouts in hornsby you work
Spotted this afternoon, a silver series 2 R33 driving through Mt Kuringai(was that you Mitch?) and a gunmetal grey series 1 R33 coming off Kuringai Chase rd Mt Colah.
could have been. but was driving in the morning.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
