spotted a wine red R32 GTR today at kellyville post office today..plates were MEL-*** i was gonna come say g'day but i didn't see you get out of the car and i went into the newsagency..then you left :)
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :D
Also spotted R33GTR (Mitch) at the RTA on my way to work... Whatchu doin there?!
Drove alongside a maroon R33 with nice white rims on Old Northern Rd last night, about 7:45? Wheels looked a bit like Enkeis, but couldn't tell while moving. Dude with a cap on was driving. I was in the black R32 if they're on here and wondering.
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :(
lol, tell your mum i said sorry :D
yeah
cbf turning a big ass 4wd lol
spotted a red R31 sedan on sunnyholt rd, BB... something :devil:
i keep driving past a black r32 through the back of rosebery, parked close by to the mitre 10 that burnt down a couple of months ago
it's a really clean and well modified gtst one of the best ive seen, and it's up for sale, if it's anyone on here good work and best of luck
with the sale.
ok so... pretty much spotted Sheng asian driving onto my grass yesterday... huge paved area, tiny bits of grass... and you get both... :ninja:
handing in notice of disposal. where bouts in hornsby you work
Spotted this afternoon, a silver series 2 R33 driving through Mt Kuringai(was that you Mitch?) and a gunmetal grey series 1 R33 coming off Kuringai Chase rd Mt Colah.
could have been. but was driving in the morning.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
