Spied a pair of white 33's at work (Morriset Square) on Sunday - One non-turbo S1 driven by some kid who looked like he was about 12. :rofl:
2nd one was an S2, low, big f*ck off FMIC and no frontbar.
On the M2 citybound this morning I saw that same black R33 that I saw the other evening pulled over. It drove past me just after the tunnel past the Beecroft Rd on ramp. BLA-33K are the plates.
Then saw a Volvo on fire on the Eastern Distributor! Crazy. The whole front was up in flames.
