Holy shit where was this
Corner of the Northern Rd and the turnoff from the M4 at Penrith. I passed it this morning on the way to work and went 'Ow'.
What time were the pics taken?
Spotted R33 series 2... not looking too healthy at all.
Note the front bumper in the grass at the back...
I feel sorry for you mate.
I'm hoping the driver is OK. If you're on the forum, my commiserations, mate.
Re. Unhappy 33
i passed the car at about 11am. i have a feeling that the driver rear-ended the car in front while trying to merge, didn't even stay long enough to see if the airbags went off, took a couple of shots and left.
i just hope he moved the car yesterday and it didn't get raped overnight.
The general rule is any damage on the front of the vehicle is your fault, side and rear damage is someone else fault. tell me if i am wrong. Thats why i feel sorry for him/her, at fault accidents suck...
i had a taxi T-bone me and it took just under 2 years to get it resolved. Good outcome though.
Re. Unhappy 33
Yes, all other things being equal, that what the insurance companies normally assume. But not always.
My old family car was totalled some years ago on the Great Western Highway in the Lower Blue Mountains. I was heading east in the AM rain and a silly old bugger (not ageism: he really was!) lost patience, and simply tried to get across the highway from the Give Way sign on the left by closing his eyes and accelerating. Right across the front of me. Of course I hit him amidships with my nose. (Though only at about 10-20ks after some serious braking).
About four people stopped immediately to offer me their phone numbers or wait for the cops, though. So there was never any doubt about what really happened. And the annoying old bugger went on a neg driving charge (still blaming me all the way!).
