hey Nick, when you say GT-R coming soon...its not the Lancer GT-R right? wehehe Jk.
so what if it is?
The Lancer GT-R is the corner stone of the JDM scene, and should be recognised.
lol..
it almost look like the done up cars in the Philippines. =)
i swear i saw a couple of them last time i visited. They love the multiple mirrors there. specially the beloved Jeepneys below! :P
so..i spotted this Mitsubishi Lancer GT-R with dual mirrors on each side, dual exhaust left and right, custom kits (mini bullbar at the rear) and custom vinyls. spotted at Blacktown Westfields. :P Oh and that black stripe to break the line is duct-tape.
Poor Lancer!
spotted KNG GTR on windsor road this morning (black r33 gtr). I putted pasted you in a yellow dc2 itr. you on here?
I saw that car in thornliegh a while ago, sounded very tuff! and not to mention it looks very nice too
so..i spotted this Mitsubishi Lancer GT-R with dual mirrors on each side, dual exhaust left and right, custom kits (mini bullbar at the rear) and custom vinyls. spotted at Blacktown Westfields. :cheers: Oh and that black stripe to break the line is duct-tape.
Now we know where to link the new kids looking for a cheap gtr to.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
