not a 'line but saw a light blue/baby blue toyota 2000GT today at rooty hill driving in the opposite direction along the bridge just past the RSL. So surreal, almost rear ended the car in front as I was looking :woot:
+ a yellow 240z datto I always see getting around rooty hill/ blacktown
Not a Skyline but saw a Nissan Cube with skylinesaustralia.com sticker across the windscreen heading towards the harbour bridge this afternoon/evening.
and I thought we were traveling Ninja style and would never get spotted in that!
jeebus! I thought they only existed in GT5
spotted a silver 33 , very nice and clean, metal ink sticker and stamp in the rear garnish part thing came into my work today and i did some tyres for ya :P
should remember me , i got stuck in your bucket seat hahaha.
also the NA white r33 with black bonnet green p's i think might work for mazda west gosford
and spotted about 5 other r33's pass my work ( usually do everyday)
Spotted, waved, & beeped the Handleys 'cruising' in their yellow GTR race car in traffic very early this morning in Carlingford :D:action-smiley-069:
perfect commuter car :D
I spotted Charlie's red stealth ute this morning
I thought so too, man if I had that, a hakosuka & a 240z I'd die a happy chappy
I was born in the wrong era :rolleyes:
gunmetal grey R34 GT? (green P-plater) tailgating me the other day, if you're on here slow down mate,
take it out on WSID wed nights :thumbsup:
two teenage looking asian guys in a black R35 GTR about 11pm tonight on the way to city along pac highway cremorne, followed them all the way to bridge.
pulled up at lights and gave them the thumbs up and asked if they wanted to 'swap'?
they giggled like school girls then gunned it on green losing serious traction (road was wet), i let them take off then went my own way.
sigh, so unfair.
Spotted a silver 34 GM30VR on cumberland hwy near m4 turn off this morning around 10am and a black 32 gtst FAT32R with gtr wing and gtr badge near bunnings ashfield on parra rd around 6pm. U guys on here?
i know that comment was from a few years back now, but just found my car on the search then. i recently just bought this car (GM30VR), so hope to see you SAU guys out and about soon!
Saw an R33 GTR this afternoon on Canal Road/Ricketty Street on the bridge over the canal.. Was that you Aphex?
If it was around 2:30-2:45ish that would've been me. Was coming back in from out west! I've given up the wave and have taken up the nod, but with my large melon it can look comical!
Spotted a stack of 33's today too, including a nice black 33 GTST along airport drive and into the M5 tunnel etc.
Yep round that time.. Mate what colour is your car?? I swear at first I thought it was midnight purple (ish) then in my mirror it was grey!
Given up the wave too.. Too many ermm.gif looks..
It's actually the factory "Dark Grey Pearl" but i know what you're saying there. I thought it was going to be midnight purple when i turned up to look at it the first time!
The car's been nicknamed "the black pearl" because everyone thinks it's a different colour... and it's a bit of a boat... and i have a red beard...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
