I saw those too, I even saw you too Mona, I was in a white pulsar as you all were pulling up to servo.
I was going to say Hi, but didn't know if you remembered me or not.
(A friend of Tim's aka. CS_180).
Looked like a good little cruise too.
Did you have funs?
of course i remember you, you star!!! :P you met up with us after a whole lot of planning and e-mails, at wisemans for the wisemans cruise!!!!!! :P you should have said Hi, and then joined us :P
and yeap... HEAPS of fun :( was a nice run ;)
and yeap... HEAPS of fun ;)  was a nice run ;)
I would have loved to have joined the cruise, but I was on my way to a farewall party, so I ended up getting sh!*faced and silly... you know how it is.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
