saw a wicked silver 33 GTR stuck in traffic on pittwater rd near the mall, sorry if u didn't see me flash my lights dude, my reactions were a bit slow and i think i flashed them when i had already passed u :D
Jeeeeezuz, i have been waiting to get spotted for agggeeees!! :D:)
I saw you man, do you live around here too??
Christian
hey wilch!  i think we need to spot each other! lol!
hehe I know!!!
I did see a black GTS-T though last night on New Line Road turning left into...ummm...hell i don't know street names :D. Didn't catch the plates. I was in my friends newly bought red s14.
wil..
hehe I know!!!
wil..
My mate just sold his Red S14, exhaust, FMIC, BOV, Filter, Lowered (not much) sunroof. Sold from Winston Hills, same car? :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
