Well I am in the process of building an RB26DETT and looking for a reliable 500-550HP build for weekend running. I have spent a bit but for the power I am looking at I am thinking about my rods, thinking about stock GTR rods and ARP rod bolts. What do they compare to cheap Eagle rods and which one would be the better option. Right now I am not ready to spend $1100USD on Carillos for my 550HP build but any advice is welcome. Have been told the stock GTR rods with ARPs can more than do the job.
https://www.sau.com.au/forums/topic/292165-which-connecting-rod-for-the-job/
stock rods will hold 400rwkw without even an effort.
The key is GOOD rod bolts and a well assembled/balanced motor. People have made more than that power on stock rods, but either way it is more than you are after so go that route.
Get them checked of course to make sure they are in good nick.
whoever told you they are fine - was spot on the money :P
Save the $1100, spend it elsewhere
Any rod on the market will be ok for the job. Factory rods included. All it takes is a shithouse tune to bend or break them. $5000 rods or $500 rods, they can all bend.
Focus more on getting the right tune
Typical engine builder blaming bent rods on a bad tune!!!! In an Rb26 you would bust pistons (even aftermarket) well B4 you bend those little rods (even the factory rods).
Well I'm not a typical engine builder but whatever man, you must be right.
There's no such thing as detonation. Or incorrect throttle pump settings causing hydraulic lock of a cylinder.
Yep, factory rods can withstand all of that. And guess what, it's always the engine builders fault. He snuck in a packet of detonation when he was putting the engine together.
I was just taking the piss mate!!! Sounds like you need to get your tuning done elsewhere tho. Mate if he hydraulic locked an engine due to throttle enrichment he must have been using like 2000cc/min injectors with a chamber volume of like 40cc. You could be 10degrees past MBT and still not bend an rb26 rod - you will however be replacing the pistons!!
Edited by rob82
I've bent a standard 25 rod... had an arias forged piston on top of it, piston looked brand new but rod, bearing and even crank were fubar
that said the standard 26 rods have been in the R for many years pumping 360rwkw... just had a bottom end rebuild due to spun bearing, rods and pistons were in top condition just resized them and chucked them back in
All good.
No need to change tuners though. Have found the ones I will be using from now on http://www.efiperformance.com.au/
I don't tune as I don't have a dyno.
You may or may not have misunderstood my previous post, though. I wasn't saying that a tuner will bend a rod, what I was saying is that it doesn't matter how many dollars he pours into an engine, it only takes one bad 'tune' (or state of tune - to clarify) to destroy an engine....and no amount of forged parts will save it, they just put up with it for longer before letting go.
As for bending rods by detonation...very hard or near impossible as, yes, it will tend to destroy the piston first...but it can bend gudgeon pins and I have seen it a couple of times. Think of the rod bending as an after effect of the engine failure caused by error in 'state of tune'
mate im gona have a set of pauter x-beam rb26 rods available tomorrow if your interested. they are brand new, have only sat in the engine
probly sell for $650 plus delivery
also have arp rod blots with them
pm me if your interested
you spun it too hard.... or making stoooopid power. :(
Trin, what ever happened to the neo?
Boy believe it or not, I did all the work on the intake side to adapt the RB26 throttles and seeing as I had to use the different set of cam caps I cannot find a local shop to tunnel bore the setup. It is just sitting there watching me everyday. If I can get someone to do the tunnel bore for me that would be great help but there is currently no one local or even in the caribbean that does the job :(. I haven't given up hope on the project but this RB26 build is for my S14.5 build that has been ongoing for the past four years, yeah seriously. My ER34 is my daily so wanted to have no downtime or as little as possible by doing everything on a separate head and block and swapping it all over. Still having hope but if I can do a setup like what RIPS did and customize the lower RB25 plenum to have the RB26 setup working then I may go that route but I may have to buy a head locally whenever it pops up. Shipping a head out of country I am sure will be very expensive and I would want to have everything done to it, like replace guides, seat valves, tunnel bore cam journals, test head for cracks and other small things same time. Will let you know how it goes.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
