Well look what I found living under my car. VERMIN!
This darn Hicas! I've done two track days and find that that feeling of the rear com'n out just totally unsettles me. So today I've got my Hicas Lock Bar installed. The GTR is a bit more of a pain due to all of the bracing that is under the car. Had to remove the rear cradle bar braces to get to the lock nuts.
Only real issue was having to stop and go to the autoparts store for a bloody $65 30mm spanner. Why did they have to make those lock nuts so big and so narrow. I couldn't get my adjustable wrench on it.
Anyway, can't wait till the next track day to loose that "squishy - tails com'n round" feeling!
Who here has done it and what were your impressions? I've heard good things.
Oh, here is the new setup:
I did a quickie alignment using a laser pointer across the wheel to the front of the car to gauge toe. It should be really close to what it was before the work as I took all the measurements before and after the work.
Funny the right side ended up exactly where it was before, but the left was out two full turns on the adjustment arm.
Yeah, next time maybe I'll check in the members forum for someone with a wrench, although didn't think I needed it until I got in there and found my adjustable spanner wouldn't fit.
Now I just have to pull the HICAS dash bulb, but at the moment can't be fussed.
I've still got LOTS of oversteer on the car, but hopefully now it will be a bit more predictable without the rear trying to steer for me too.
I'm going to try some tweeks today to get the oversteer under control. I just want to get everything to stable base line - hence removing Hicas first.
I bought this lock bar from Unique. It is the Chromoly one which should be very durable and slightly lighter than steel. Although, it's already a big improvement in weight from the Hicas unit. Most are about the same but be sure to get something that is quality, I'd hate to think what would happen if a weld came undone at speed!
I've also got a fair bit of suspension mods done to my car - Greddy S-type coilovers 6/8 weight springs, adjustable bushes & adjustable rear camber arms. Next will be Caster bushes, rear subframe bushes and swaybars.
From what I understand Hicas doesn't kick in until you are doing some speed - like 70kph. So on the street it generally won't make too much difference just on the highway.
I'm taking it out to Wakefield on Saturday so will post my impressions.
So, I took the car to Wakefield yesterday. This is the first real track work I've done sine removing the Hicas. By the end of the day I was feeling so much more comfortable pushing the car. I must admit that I pushed it too hard in 2 of the morning sessions so gave myself a "time out" to get my head straight.
My car is still too heavy to really slide hard into corners, but my exit right hander onto the back straight felt so good. I can enter at 110+ and use the throttle to slide to the outside up to the ripple strip on the back straight. It is SO much better than before.
I managed a best of 1:11.7 (timed from video/frame accurate) - so I'm really chapped! I know the car can go faster, but I still have a ways to go to learn to drive it right. Removing the Hicas has been the biggest aid so far.
so there you go - highly recommend!
so standard hicas is bad for drifting? silly question probly but i want to set my 33 up to drift so the more i know the better.. how come hicas is bad im taking because it "steers for you" rather than you being in full control?
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
