  • Replies 319
Posted Images
You got lucky!
I deleted it thinking it was spam... It's probably a good idea to put SAU:NSW Show N Shine in the header otherwise I'll delete it.
That inbox ONLY gets spam so make it obvious... 'Please confirm receipt of entry' probably wasn't the best way to get my attention :P
It's all good now though mate :D entry received!
WOOT! I KNEW I WASN'T THE ONLY ONE! :P
Yeah I dunno why either, but that seems to work pretty much all the time from the office as well... hasn't worked without the 02 yet...
If you can't fax, just mail it off to:
SAU:NSW
PO Box 119
Pymble NSW 2073
And I'll write up here if I received it or not :(
Mail received recently includes:
Shant Nazarian
David Milano
Stan Choi
Mitch Smith
Genelle Bill
Jeff Cook
Rami Sadi
Hey guys
Can you please confirm my entry?? Faxed it on Friday 19/11. Attached it as .xls from my works email program. not sure if it would have opened up on your fax machine?? Could you also confirm my payment of $10 ??
I am happy to resend via fax if it didn't work.
Cheers
Being completely off topic and all.
Since this is being labled Godzilla's 20th birthday and what is seeming to be the big event..is SAU:NSW still planning on running the 21st Anniversary cruise that was originally discussed between Terry_GTR34 and N1GTR?
Cheers
Nick
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
