  • Replies 319
Posted Images
mine went with my membership paperwork. dont know if it went to duncan or liz. can we confirm
well if it went to Liz you are shit out of luck cos she has nothing to do with the sns lol..
That's what happens while you try to copy down all the names in the middle of a meeting while still giving up your 2 cents...
hahahah Just count yourself lucky i didnt give you my full greek first name. lol
All you guys have done a great job so far with an entry list already that large, big well done :D
Hi Duncan ... sent through fax with entry details that you should have & money via electronic transfer that will show by tuesday ... cheers Malcolm :)
Hi Duncan ... internet transfer completed this morning at 1015 ... cheers malcolm :P
any 1 know when the next batch of membership stuff is being sent out by the way????? been waiting abit
PM Shell. though, it should be soon as everything needed for the packs has been received recently or is on its way
I agree with Slim, it will (should) be very soon as we were waiting on SAU:Vic (blame game! :D) to send us 200 lanyards... Apparently they brought in an exchange rate too cause we only got 150 ;)
I faxed Both off to the number on the forms. which were both the same i think. should i fax the form off to another number than ?? if so which number. the money is in the account as my memebership has been put through.
Newcastle/Central Coast people: should we cruise together from F3 servos or something????
:(:D HELL YES WE SHOULD :banana::banana:
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
