  • Replies 139
oh yeah..
It was a great day! Thanks to everyone that came, thanks to everyone that helped out on the day, thanks to everyone that donated money to the RSPCA!.. now we don't feel so bad about that wombat..
Thanks to those of you that actually booked your lunch ahead of time and gave us the money..
luckily for everyone else you still managed to get a seat.. next year we need to leave about 30 minutes earlier... and head straight to the pub.
I think we raised around $700 all up! great effort! Nice to meet a bunch of new faces and catch up with the regulars. Don't forget to sign up for the Show and Shine.. no excuses... NONE! :happy:
thanks again to everyone who came, behaved themselves and hopefully you had a good day as well
Sam
https://www.sau.com.au/forums/topic/293299-putty-wrap-up/#findComment-4897949
about 70 cars from Kel's count....I'm sure someone can post a photo from the park at the end there were cars everywhere.
thanks everyone for keeping it sensible, afaik the singleton hwy patrol made no money from us today :happy:
RSPCA on the other hand did, at least $600.
And some great committment from the travellers today....I thought the coasties and gong-ers had done well. Then I met the guys from Newcastle...Canberra....and the winners up from Wagga Wagga for the cruise :)
https://www.sau.com.au/forums/topic/293299-putty-wrap-up/#findComment-4897996
Thanks you staff for organising this. Drivers' briefing is one of the best I've heard.
The trip back to Windsor was a hoot.
2 cars became 3
3 cars became 5
5 cars became 7
And I don't mind saying that 2 of the drivers with 110years+ between them, kept the convoy 'up to speed' eh Humbla?
We even wriggled around a smash. Was that a wedding car?
There were sooooo many gorgeous cars there too
Tai's R32 must be entered in the SnS
Che's R34 - well what can I say but for the fact that he wouldn't let me eat off it
Dave's R34 in red - what a colour?
Midnight purple R33 - one of the best colours ever made too!
All the great ppl there that made me welcome again & can now put faces to names but the personalities count even more! :happy:
https://www.sau.com.au/forums/topic/293299-putty-wrap-up/#findComment-4898114
2 cars became 3
3 cars became 5
5 cars became 7
What a day,so much fun,just got home.Top job done by every one as usual,nice to meet new peeps and see the old ones as well.Terry enjoyed cruising back with you and the others was awesome,looking forward to the next cruise. :happy::)
https://www.sau.com.au/forums/topic/293299-putty-wrap-up/#findComment-4898142
6.3 Gig of vids and pics to sort through, plus the dvd footage from terrys place...
including the special event.. Aggro chases down Terry :happy:
Will post up later tonight, first things first.. food and shower!!
Nice to meet all of you and to put faces to names for the others I didnt get a chance to meet.. I think I still won for loudest exhaust :)
It still sucks that I fail on the uphill parts. Must get turbo.. screw P plates
https://www.sau.com.au/forums/topic/293299-putty-wrap-up/#findComment-4898152
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
