ok, what are peoples experiences with the Electronic Boost Controllers? Id love some feedback with ease of use, installation difficulty, value for money and of course, the good, bad and downright ugly of em all. Ive read a few writeups on turbosmart e-boost and blitz ebc's but companies generally write what they want you to know.
Cheers, Allan
https://www.sau.com.au/forums/topic/293495-ebc-recomendations/
Hey mate I can't offer any real feed back but I'm looking at a HDi setup.
So far the reviews I've found are good and it seems to be a reasonable price for the simple all electronic setup. So far this is my pick for bang for your buck so I'll let you know what its like when I get mine at xmas.
what sort of prices are you looking at buddy? as there is quite a range out there,
bang for buck i couldnt go past an hdi one - however i went for the model below, the one without the gauge (as i already had one)
its a nice little neat device and the delivery from the supplier was equally nice hahah
i may even know of one for sale in the Brisbane area in immaculate condition...complete with optional Blitz Power Meter.
do you know what colour? i got the URAS edition and the white stands out a bit against the dash..
its just the regular grey colour...the white ones are a bit ricey.
who said AVC-R?...lol...try running 24+ psi with an AVC-R.
Ill have to post some piccies one day of my death machine, methanol and 36pound into a 1.8l sohc subaru donk of the 1980's vintage. was my weekend warrior for the drags but ive been commanded to get rid of it lol, i have spent waaaay to much money on it. Thanks for the input guys, its great, as for DirtGarage, id love to know more of the ID III please good sir. I was also recommended an AVCR or Blitz by another person so it seems there the go! Hopefully that gearbox is well on its way to getting built and my turbo's will arrive mid next week.
Cheers, Allan
I run a basic Blitz EBC at 25 lb and have never seen an issue with it Allan.
Have a few friends all running 20 plus lb with a variety of ebc's as well.
The most popular big boost ebc at Jambo that I saw was the turbo smart job. Some of those guys were running insane amounts of pressure through those things.
I did a review on the AVC-R vs the SBC ID-III a few years back...
You might find it helpful... I personally believe the ID-III is probablly the best money can buy, they just so realiable and easy to use...
I Also agree with Paul, the AVC-R can be very touchy with high boost applications... Most single solinoid controllers face this issue when using a high gain...
Anyway, link to the review I did ---> http://www.skylinesaustralia.com/forums/SB...ml&hl=avc-r
all the time buddy ! :D
have you mapped whats actually occurring on a dyno with the AVC-R at 24+?
we changed from avc-r to Blitz ID-III and made the same power with 2psi less peak boost.
Have used the Blitz ID-III to control boost on several low mount twin internally wastegated and single high mount externally wastegated set-ups up to 34psi...solid as a rock!
Edited by DiRTgarage
Didn't you hear Noel ? He has a turbo'd micra that makes 50hp on 25psi of boost. The turbo is actually a specially designed straw that he blows into while he's driving. He gets them for free from the Baskins store.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
