So yesterday I was picking my little sister up from work and on the trip home this cattle dog chases a plover right in front of me... Next thing I know I have collected a sign post and am surrounded in dust. Thank f**k we weren't injured at all!!
So now I am looking to get my baby repaired, but before I take it to a body work shop I would just like to ask you guys what you suspect is wrong (apart from panel damage) and what I should be looking at price wise for the repairs. Just ball park as I know each shop is different.
So here are some pictures and as you can see I collected the sign post right in line with the drivers side rear wheel. The wheel has moved in at the base, which the tow truck driver suggested is from the control arm being damaged. I drove the car up the driveway at home and didn't notice any obvious bumps and jumps as if the axle had been damaged though, but then again I am not mechanically minded so I wouldn't really know...
Any help would be appreciated.
Chris
post-61364-1256510876_thumb.jpg post-61364-1256510935_thumb.jpg post-61364-1256510987_thumb.jpg post-61364-1256511051_thumb.jpg
https://www.sau.com.au/forums/topic/293537-crashed-my-car-yesterday/
Looking at that control arm I would definitely be asking them to look at your subframe/chassis alignment mate. Its taken quite a hit there.
Noone here can give you even rough pricing unless they are involved in the accident repair bus. Take it to a couple of reputable repair shops and compare their notes.
Camerons bodyworks at Coopers Plains always seem to get a mention around here as being upfront and of a good standard when it comes to skylines.
I've had no first hand experience with them but it may be a good place to start.
Thanks for the input FineLine. Sounds like a good option but unfortunately I am up Townsville, probably should have mentioned that before sorry.
As for your suggestion that I could have subframe/chassis alignment issues, how complicated is repair in the worst case? Need to source replacement, or can these type of things be reworked??
Any body shop worth their salt will have chassis equipment mate. have a look around.
Looks ok. Just chuck in a arm and see what its like or You can just replace it with an adjustable lower arm off ebay and it does not matter if their is a alignment problem as you can adjust it out. Had the same damage on my old r32 and thats what I did
Thanks for the suggestion Brokenz. I just need to be as informed as I can be when I approach body shops and these inputs, solutions will help me heaps when I quiz the mechanics. So I will get some feedback from a few shops about the drivetrain (right word?? chassis) issue.
Can any panel beaters out there provide an estimate for a full rear quarter panel fix and respray?
... LOL would I have swerved if it wasn't on the road?? Now that I think of it, would it have been better to have hit the damn thing??
Ok so the old man knows a mobile mechanic at Cannington that is going to take a look at it on Saturday. So should I get hold of a control arm (found one for $225 delivered, is that reasonable?) so he has it on hand?
Better for you, but I'd take all necessary safe steps to miss someones dog personally. But then I'd also attempt to capture the dog or at least burn an image into my mind so the owner can pay.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
