  • Replies 52
i was thinking of a vent in the bonnet above the pod filter as well, however the main problem then is water getting into ur engine bay and if driving ur induction system! would need to have like a drainage system or like a vent cover so in the rain u can drive, but no cold air :cheers:
I wouldnt know which one is the loudest, but heres a comparison somebody did between different filters. Apexi was the best :D
http://www.mkiv.com/techarticles/filters_test/2/
I have an Apexi pod, but I found that unless you're using a cold air partition, the HKS gives you noticably more power. I *think* this is because it faces more to the front and has more of a face to the incoming cold air, whereas the Apexi pod can suck in hot air from the sides. But when I put the box in, the power was pretty much the same for both (I couldn't tell the difference anyway).
If you didn't want a cold air box/partition, I would probably prefer the HKS filter or another one of a similar shape. Although then you have to worry about the particle filtration, which was my main concern when choosing the Apexi pod.
  • 1 month later...
I've got a Blitz SUS LM on mine, and yup, its friggin loud. You can hear it sucking, even when slightly cruising. With the window down its probably the loudest thing you can hear in my car! Its kinda cool, and annoying at others - but its staying on.
So if a cop pulls any of you over, and pops your bonnet, and sees a pod/s they will defect you right?
I had a large K&N pod on my old car (Alfa Romeo) but it was on the end of a pipe which I had custom made to sit down very low away from the engine and close (but not too close so that it sucked up water from puddles in the rain) to the road. And the cops would never have found it because you couldn't see it but damn could you hear it!!!!!!
I want to install duel pods in my RB26 but I don't want to get defected!
Guest RedLineGTR
Best Bet are get a photo of it possbily and post it in the for sale section (parts) and most likly some one will buy it u just have to figure out a price to sell it...how much u ask?? i have no idea. I have found that people have still been buying them, so all i can say good luck.
Cheers Rob
Guest RedLineGTR
Also those tests are with a high concentration of particles and toxins, and it never gets that bad on "normal" roads, but to stop the really microscopic particles u can’t use foam at all. Best bets are for a Mesh type filter wet or dry, out of the tests I would go for the apexi one but i personally want one that i can clean nothing is clear forever and will eventually restrict flow, I myself have a k&n filter with the light oil it has and the Mesh type filter I’m pretty sure its doing a good job (I don’t believe 100% those test u don’t know if they are new etc). My 2 Cents.
For those running the Blitz Sus LM are there any temp problems and how often do you clean them, if at all?
I'm thinking of buying one, but i can't find the Stainlees steel one. Only the..er..non stainles steel. hehe
The review, earlier, shows that it does not filter that well. Has anybody had any filtration problems while using a Pod?
I currently have a K&N panel filter in my standard air box. You can hear the induction noise from the inside and a slight BOV sound, but it's not that loud. If the radio is on all you hear is the exchaust......and the radio of course!! :wassup:
    • Depends on the year/model - mine is the version of the N55 which came with an e-gate however the "PWG" (pneumatic wastegate) versions actually can also do this.  They use a vacuum setup to "pull the gate open" against the spring instead of "push it closed" like conventional wg setups.   This naturally means they can actually control boost down to a very low level/just open the gate if they want to.
    • They have e-gates. At cold start they have the gate fully open to heat the cats faster. Then during cruise as mentioned fully open wastegates reduce exhaust pumping loss.
    • Ill stick with my black Friday sale pirellis.  They were the factory option and a damn good price when on sale.
    • Hi Tao. My dump was ground out to provide clearance over the used swing arc. But when the clip fell off, the flap was free to travel too far. Got stuck. That's all. There's decent preload too. You may remember that I asked for a low pressure actuator because I wasn't able to tune the car immediately, and a proper actuator probably would have left the car undriveable. Or at least barely safely driveable. But it hasn't been an obvious problem in terms of the gate blowing open under normal use. Well, maybe it has. The turbo is quite laggy compared to stock - so an actuator upgrade will be done first after the supporting mods are done and it's dyno'd to stop it pinging. Hopefully the gate has actually been lifting early. If it has, it has been necessary for me anyway, because as I said earlier in this thread, I had to back off the ramp allowed by the boost controller, to stop it pinging. I might have been in a bit of trouble if it hadn't been as slow to build boost as I have found it. In fact - given that I will get it onto the dyno soonish - I think I'll order an actuator from you pretty soon, so we've got it there if it is clear that there's no point continuing to try tuning with the low pressure one.
    • I've always wondered why my brothers BMW is louder in Eco mode. Do they have e-gates from factory?
