only on RS models.
yup. :cool:
mine hardly moves so maybe ATTESA wakes up a little more if you have bigger tyres on?
If your car has more performance/torque then that would definitely account for it. The computer will think the rears may slip so it will direct torque to the front. Apparently it improves acceleration anyway...although I've never looked into it.
Hey Guys,
I finally got a set of wheels for the M35... I got some Enkei GTC01 in 19x8.5 +22 Tyres are 225/40/19
The fitment is perfect! exactly what I was going for in terms of filling the guards. Check out the pics
Some of you may remember I tried running a staggered set a few months back but had attesa issues.... Well I have now bought a set of 4 matching wheels and tyres, and still have the attessa shifting torque to the front when it doesnt need to.
Has anyone had this issue with aftermarket wheels on the M35? I never had this problem on my C34 stagea. Any advice/ideas would be great.
In the mean time check all the pics below! Im loving them :cool: I now have loads of room for 350Z Brembos :P
Ben.
Hey mate sweet looking Stag,
Same colour as mine :P
What is the front bar and side skirts on it? I like the look of the front end with the fog lights.
My stag will send drive forward under heavy acceleration, 4-7000 rpm but not for long and usually only in first and second gear......not really words of wizdom but might put your mind at ease. :thumbsup:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
