Hi guys
I've noticed my Rb26 (R33) slowly looses oil over a period of time.
I've done two oil changes so far since i've had the engine and had to top up about 3/4 to 1 quart over the 4000km i run the oil for.
The first time i used Redline 20w50 and thought it was just probably the oil so i tried Schaeffer 20w50 but same result.
There are no oil leaks anywhere and when i opened the catch can after the two the oil changes there was only just enough oil just to cover the bottom(greddy)..... just a few drops really.
Compression reads: 172 / 175 / 173 / 170 / 156 / 160.
There is no smoke on start up, and my friend who was driving behind me says there is only some black smoke for a few seconds when i floor it.... no blue smoke.
It is running really rich because it has a little soot on the back and pops every now and again when a let go.... stock ecu running 12psi
Other wise car pulls really good
Where does my oil go???
https://www.sau.com.au/forums/topic/293879-disappearing-oil/
Check your cam cover gaskets. Notorious as shit on any skyline of its age. I'm forever replacing them for customers that lose around half-1 litre of oil every 5000km.
And it won't be your oil control rings, all they do is drag oil up the bore. Even if you were referring to the second ring it wouldn't be that unless it was blowing smoke, which he said it wasn't.
The only reason why I'm repeating it is because when you are losing oil...and you know you have a leak somewhere....no matter how big or small, fix the leak first, then ask the question.
It's common sense. It's also at the top of the engine so it's the best place to start considering the oil will move in a downward direction.
Here's a picture of a GTST with a normal leak from the rocker cover gasket.
It was also leaking from the front corners behind the top timing cover backing plate and leaking from the half moon seals at the back and leaking down on top of the gearbox.
This one appeared not too bad from the top. It wasn't until looking from underneath that you will see where it is coming from.
My 32GTR is daily driven about 110km each day of the week and I don't lose oil like you are stating. I had the rocker cover leak at one point but just tighten the screws up regularly now and don't see the issue anymore. But it is apparently a common thing for the rocker covers to work lose.
Nissan says the standard is 170 psi with a variance of 14 psi across cyl so the lower numbers (156,160) is what i would actually expect for an engine with this kind of mileage .....water pump,timing belt,tensioner etc. has already been changed in Jap.
Its the higher numbers that has me baffled bc i tested a next 26 with a genuine 25k on the clock using the same gauge and all cyl were between 162-170
Did you have a jump pack connected, throttle fully open and all spark plugs out for the compression test?
If not, then the results don't mean anything as they will most likely be a few psi off...usually under
I have never had to top up oil on any of my RB26s and i've had a fair few, from stock 1989 engine to brand new N1 Nur motors to built motors and none of them used oil between changes. granted my changes tend to be fairly quick as most got some track use and get fresh oil then, but they always gave back out pretty much what was put in. there is definitely something wrong happening. in normally healthy state RB26s do not burn or loose oil.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
