Have written a few threads about this recently & Im sure some of you are sick of them but I need to try & find an answer... Had no car for months!
My RB25 is badly overfuelling on idle & all through rev-range. Injector pulse at idle is 7ms! Have no vacuum/IC leaks, have tried other AFMs & temp sensors, all with no luck... 1 interesting thing is I was told to unplug AFM & see what happened... While unplugged, the idle stopped hunting & exhaust stopped smoking, however you could smell it was still a bit rich. When I plugged AFM back in & went to rev engine, it was still in limp mode. I turned car off & on, same thing... Eventually with AFM plugged in I wiggled the wires & it came out of limp mode. It seems even moving where the AFM wiring meets the main loom has some effect on idle, (in & out of limp mode) but still nothing perfect. Does this give anyone any ideas? (bad earth from ECU to AFM, etc...) Really going crazy!
Any help appreciated
https://www.sau.com.au/forums/topic/294411-rb25-still-overfuelling/
I had a bad afm, the solder on the connections inside the afm from the plug had broken, another problem could be that you have a short in the plug its self, try another afm and see if it makes a difference.
How do you know the injector pulse time at idle?
Check that you have supply voltage (12V), continiuty of the signal line to the ECU, and check the ground(s).
Had short use of a scantool to check live data...
So supply voltage to ECU. Signal line from AFM to ECU? & does anyone know which pins in ECU are earths? Have a pin-out but unsure of accuracy...
Checked all this today, came back fine... Every test I do comes back fine although there is obviously something wrong...
Any chance ECU could be at fault? Or anyone have any other ideas?
Thats what Im starting to consider... Possibly a fault in the ECU itself. If it is thats fine, ill go get a Z32 ECU tuned to suit by Dr Drift or similar but if its not I dont have a clue what to try next
If you in the frankston area i have an ecu here you can try to see if it is the ecu.
Thanks heaps mate but series 2 engine so possibly some difference in ECU... Seriously appreciated though
I believe S1 and S2 are the same, you can use the same model power fc on both, i believe the differences are outside the ecu, like the coils, S1 have an igniter for all 6 coils but S2 have an igniter on each coil, the ignition from the ecu is the same on both though, maybe do some searching and see what you can find, iys here if you need it.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
