I have a r33 s2 (auto) I have a problem that is really giving me the shits.
problem is that when i put it in gear it drops in revs almost to the point where it stalls. this has only just started last week.
It idles good at around 800 to 900 rpm,
I have cleaned gthe AFM (and tried another one),cleaned the AAC, New plugs, Split fire coil pack which would be roughly 10 months old,replaced all the vacumm lines (thinking it was a leak in the lines), new fuel filter, auto was serviced 6 months ago and all new fluid was put in (levels are good)
I have been reading possible problems that it might have been, This is why i have cleaned and replaced all that i can think offf.
If any one might be able to shed any light on this it would help me out heaps :D
https://www.sau.com.au/forums/topic/294435-need-help/
I would be taking it back to the guy that did you 100k service and put it in his court. Obviously something he has done has contributed to this.
Possibly the timing belt was not tensioned correctly and after some kms the timing belt has stretched as they do and it may have jumped a tooth.
Does the car drive normally when you get it going??? Or does it just continue to die?
I'd definitely be taking it back.
https://www.sau.com.au/forums/topic/294435-need-help/#findComment-4915636
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
