After a Jap wrecker that has halfcuts, or just general skyline bits and pieces anywhere in Southeast QLD. There are quite a few in melbourne and sydney, so must be some up here! Please let me know of names and numbers.
Most specifically after a front drivers guard for R33 Series1 for under $250 (what i paid in melb).
https://www.sau.com.au/forums/topic/29466-skyline-halfcutparts-place-in-se-qld/
RMA, I think that's where I got my A/C Compressor off. They are a bit on the expensive side, but they are apparently the only reputable import wreckers on the gold coast, so I gather they can charge anything they want.
The addresses are:
  • AllJap Autoparts at Underwood
    62 Kingston Rd
    Underwood 4119
    (07) 3841 0066
  • RMA
    43a Egerton St
    Southport 4215
    (07) 5532 7914
Problem is, I aim not to spend wads of cash to get a discount :)
Anyhow, went down there to RMA.. driver side front guard was $275.. About same as melbourne prices, so reasonable i guess for an import.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
