SL!M's Avatar
79 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
You've had different sigs tho slim...
f*k knows what they were though!
i've had heeeeeeeeeeaps of different sigs lol.. and different avatars.. but this has stayed the longest.
wasn't there one with him behind a giant camera?
yeh that's my profile picture, that's still there..
we should have a poll then of who has the best avatar...
personally i think it should go to silver gtst.. his avatar rocks... and has done since ive been on here.
that said... pepe lopez's is pretty awesome.
i decided to change mine a little while ago... dunno why.. i had the same one since day 1.
I'm so not a clown person... and for some reason that sends shivers down my spine (And page one kills my PC damn you Sammeh!)
But the clown must stay...
And doof, they're your missus' tits aren't they?
If I had a missus with tits like that and I could use them as an avatar I would... :)
I think its a good moderator avatar.... it shows that someone is always watching.....
and Sl!m has had that avatar since i became a member and its iconic to the many times that i started pointless threads when i thought he wasn't watching and then BAM!!! LOCKED THREAD!! that clown just came outta no where man....
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
