SL!M's Avatar
79 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
You've had different sigs tho slim...
f*k knows what they were though!
i've had heeeeeeeeeeaps of different sigs lol.. and different avatars.. but this has stayed the longest.
wasn't there one with him behind a giant camera?
yeh that's my profile picture, that's still there..
we should have a poll then of who has the best avatar...
personally i think it should go to silver gtst.. his avatar rocks... and has done since ive been on here.
that said... pepe lopez's is pretty awesome.
i decided to change mine a little while ago... dunno why.. i had the same one since day 1.
I'm so not a clown person... and for some reason that sends shivers down my spine (And page one kills my PC damn you Sammeh!)
But the clown must stay...
And doof, they're your missus' tits aren't they?
If I had a missus with tits like that and I could use them as an avatar I would... :)
I think its a good moderator avatar.... it shows that someone is always watching.....
and Sl!m has had that avatar since i became a member and its iconic to the many times that i started pointless threads when i thought he wasn't watching and then BAM!!! LOCKED THREAD!! that clown just came outta no where man....
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
