I use it on my dump pipe. Stinks for 100kms or so till it burns off the bit of oil or whatever is in it. Many people say it's a waste of time. At the end of the day... there might be better ways to heatproof stuff like hpc coating for example but if you've got it already then might as well use it. Just use hose clamps i don't think they need to be anything special although they do sell specific ones but i think that's just because they're narrower. Only thing that you could do that you wouldn't have to fix down the track.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920264
thanks heaps bro
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920373
steel cable ties or stainless wire does the trick. using heat wrap can create hot spots in manifolds tho and with some aftermarket units using it voids the warranty. in saying that i use it on my dump pipe and hot side intercooler pipe
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920708
i used it on my front/dump pipe to help keep the heat down as best i could in the engine bay, im pretty pleased with how it turned out. the hot tip is soak the heat wrap in water for a minute or 2 before you wrap ya pipe, make sure it overlaps by 1/2 or 1/3. secure it with stainless hose clamps, and ya laughing old mate.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4921650
Soaking it in water is a BAD thing to do... Heat wrap will trap moisture and rust the pipes...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4922064
The wrapping dries out with the heat of the exhaust anyway, doesnt hold any moisture that would rust the pipes.
The best thing to do is paint the piping/manifold with high temp paint to seal it, then use the wrap.
Soaking it in water makes it easier to do a good install (nice a tight with good, even coverage)
Ive heard that wrapping isnt that good to use on stainless, but i used it on my extractors (when i was NA) and never had a problem...
Im using it on my steampipe turbo manifold and considering it on the stainless dump to keep engine bay temps down - dunno about the dump being stainless tho.
+1 ceramic coating is the shit, but VERY expensive, heat wrap does wonders for engine bay temps.
Also use it on my oil return line that runs very close to the exhaust, along with hotside I/C piping...
Oh yeh and use gloves when you install this shit, or youl be picking out invisible fiberglass splinters for weeks to come...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4922612
Really?
I know a lube mobile mechanic that swears by it.
Reckons thats all he/they did in europe.
I've been warned of it by a couple of workshops.
Plus, why do you need to do it, it isn't like it's stiff or anything, it's very easy to manipulate.
Oh, and the old heat wrap on the oil lines... Saves them splitting and causing fires! I have it on my return line too...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923255
I was told by an exhaust shop not to wrap my stainless dumps as it would make them become more brittle and prone to cracking
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923647
Ceramic coating isnt as expensive as some people may think... Guy I work with just got a pretty long set of extractors done for less than $200 at HPC... We get trade price because of where we work but cant make that much difference... Definitely worth it too
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923689
Its good to wrap your turbo downpipes and ex.manifold with those heat wraps.
For those who have doubts, make sure the heat wraps are soak in water for an hour
to soften the wraps. Wrap it as tight as possible to prevent future twisting and rubbing against steel surfaces/pipes.
By doing this, your pipes or welding joints wont get brittle and create cracking.
Once its soaked, wrapped and securely fasten with driveshaft ties, heat the engine up and slowly let it dry.
You will see how good it looks compared to dry wrapping. Doing it the right way will really help to cool the engine bay.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4924417
as MrKotter said..
Wrapping will cause your mani/pipes to become brittle.
The wrap will keep the heat in and your mani/pipes will run hotter. This WILL lead to cracking if you have low quality parts and is only truly needed for race applications.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4930627
Pretty much heard the same, not so bad on mild steel though. But with stainless it can cause it crystalise by keeping the heat in too much.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4931094
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
