Hey guys, in need of daily. Looking at spending up to $10k, but would rather spend less.
Needs to be:
- Decent on fuel
- Reliable
- Not girly
- 4 door
I don't want something too old, or with too many k's. Whilst looks aren't important, I'd like to have something that wasn't hideous or too girly.
I'm really quite stumped, so I'd appreciate any help.
Thanks.
https://www.sau.com.au/forums/topic/295087-recommend-me-a-daily-driver/
  • Replies 44
AE92 SX FTW!!! 4age screamer... lots of fun for a daily... love to be thrashed.
or
early 90's civic... the things never die.. i bought one for $300... had a little bit of rust.. its been going strong for almost 2 years since i bought it... ive washed it once for rego and topped up the oil and washer bottle... thats it! it goes good, comfy, quiet, has air con, quite roomy. brilliant little machine!
or
What's fascination with the 4age anyway? I looked it up on wiki, but it mentions nothing about the cult following it has.
To all the others, thanks for the responses too.
Cult following may be due to the fact it was the weapon of choice in initial D.
Realistically, they are a friggin brilliant engine. sound good, go hard, easy to work on, makes decent power, and paired up with an AE82, AE92 be it hatch or seca, or the levins from year dot to year line.
I reckon either a quick little runabout like the ae92 corolla secaSX with the 4age powerplant, or something cool. like this:
newer
Cressiddaaaaaaa!!
Edited by Dorigecko
dont rely on the internet
too many people try to buy cars on the net with no idea what they are like to drive...everyone has different perceptions as to what is good to drive...any car can be good if you treat it right...try stick to decent brands as you would if buying a tv or something...that way you get better resale...
Just go down to a carsales place and try a few different ones...youll know what to buy when your in it..
then find one on the net
Edited by doozooby
Hey, why did you want a daily when you have an n/a supra?
My gearbox just blew.
I'm considering selling the Soop and just buying a daily driver till I'm of my P's. Not worth having a car like this on my income when I need it for daily driving.
Well if that is the case i would be getting somethin a fair bit less than $10k. That way you can save more for the next proper car (after p's).
Corolla's for like $3/4k are pretty much trouble free.
BUT that is easier said than done :cool:
As a rule of thumb, "cult following" is a euphamism for "weirdos who like dumb shit". Notice how all "cult movies" are rubbish?
Seriously, though, the 4AGE is good for what it is. Some of the good ones pushed 100kW, which is not a bad figure for a 1.6L engine now, let alone back in their day.
They're also very physically compact, which is why you see them getting dropped into kit cars.
They did get used for motorsport, so you do find a fair few mods for them and mechanics who know how to build the engines up.
I would have suggested a N15 Pulsar SSS but they are a bit long in the tooth, and Nissan build quality isn't fantastic. They did come standard with everything you'd need in a daily (air con, power windows/mirrors) and the SR20DE isn't a bad motor. Any Nissan hatch after the N15 isn't even worth considering.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
