Was driving through the city last night (La Trobe) and got pulled over for a *random* (my arse - the cop came up the tram lines to over take all the cars behind me especially to pull me over) license and breath test.
He got bored while he waited and got defected for bald tires :cheers: He didnt pop my bonnet thankfully, but looked inside, and said that my boost guage was ok (mounted on steering column) and my razo knob was ok cos I had the shift pattern sticker next to it.
Anyway, theres nothing about paying a fine - but do i need to pay to get it cleared at VicRoads?
dave
https://www.sau.com.au/forums/topic/29542-got-my-1st-defect/
hehe dave... thats nothing to worry about. as stated u just need to get the tyres replaced and while ur there tell the guy u had a defect for it... probably give u a slip of some sort for u to take to VicRoads... or they will just come outside and take a look when ur at vic roads... no need for a full RWC.
https://www.sau.com.au/forums/topic/29542-got-my-1st-defect/#findComment-603504
Yellow defect - need to present my car to vicroads and have all 4 tires cleared. Been on the tread markers for about 500km now and been planning on replacing them any way. Rego is due on the same day as the defect thing, so do that at the same time.
So if anyone has 215/16 tires for a good price :D - i may just change wheels if i dont find tires.
https://www.sau.com.au/forums/topic/29542-got-my-1st-defect/#findComment-603680
haha it had to happen sooner or later.
U dont even need to take the car to vic roads, just take a receipt showing the purchase of the new tyres and vicroads will clear it for you. If they ask to see the car tell them you were told not to drive the car until the sticker was cleared. Vicroads are so busy especially if u go in abount 12.30pm they dont have any spare time so they will just pass you.
https://www.sau.com.au/forums/topic/29542-got-my-1st-defect/#findComment-605436
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
