I was of the impression that RB26 and RB25 bellhousings were able to be swapped without implications.
Both bellhousings fit RB series motors and both will fit RB25/26 gearboxes.
Use the slave cylinder, clutch fork and pivot to suit the bellhousing.
I found an RB25 box and clutch for cheap, only catch was it had a custom bellhousing (to suit a VQ motor). So I bought it, found an early (push type) RB26 bellhousing and swapped them over. So RB26 bellhousing on an RB25 gearbox.
Fitted the gearbox into my car only to find that the shifter is now about 50mm further towards the rear of the car, I'd have to cut into the shifter hole to make it fit.
Plenty of people have fitted RB25 gearboxes without shifter position issues. So makes me think that the RB26 bellhousing is longer than the RB25.
Can anyone confirm this, or can anyone take a measurement of their bellhousing (early RB26 or RB25)
https://www.sau.com.au/forums/topic/295603-rb25rb26-bellhousings/
Gimme a call tomorrow 0407 111 229 and I will measure the two gearboxes I have. Will need reminding though, hence the phone call
I called. No answer, so I left a message.
Will take pics tomorrow afternoon.
Edited by daisu
Took some measurements.
An R34 manual gearbox. Bellhousing was approx 400mm, and the rear housing was approx 410mm.
My gearbox, the RB26 bellhousing was approx 400mm, and the rear housing was approx 460mm.
So f**k knows what gearbox it is. It looks like an R33 gearbox (has that slanted section where the shifter plate bolts onto the box).
The gearbox in that link is a Z32 gearbox, I sold it because I didn't want to stuff around with the remote shifter
I am well aware of the differences between a Z32 gearbox and an RB25 box.
The gearbox I have, It looks exactly like an RB25 box, it has the slanted section where the shifter plate bolts down (it doesn't have a remote shifter).
Word from another forum is that it may be from a Cima?
Edited by daisu
Okay, been doing some more searching and found that some models of Z31 were fitted with bigger gearboxes (have the same internals as the Z32/RB25/26 etc) but they did not have the external shifter linkage. So going from the photos it looks identical to the RB25 box.
The gearbox code for them was FS5R30A, which also matches up with RWD navaras. So have a few more leads to chase up now.
Yep, I've confirmed by measuring the length of rb25 and rb26 bellhousings (approx 400mm if anyone wants to know).
I measured the rear housing of a mates R34 RB25 rear housing at 410mm, mine measured up at about 460mm.
Also had another look at some photos of 25 boxes and compared to mine my rear housing has an extra bracket underneath the shifter. It's definitely a completely different box.
Looking at more photos, it looks exactly like the larger box found in late model turbo Z31 300zx (has the same internals as the Z32/rb25 etc). So now I'm a member of auz31 forums trying to get them to give me a hand identifying it.
Phew, who would've thought a 25box conversion could turn out to be such a hassle!
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
