Not really, When i was on my p's i head a cooler,exhaust, podys,bov's car to low etc... i use to get pulled over by the same officer and he would just dick me for the same things when i take them on and off.
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934462
No, same again. Maybe go about it a smarter way though, get a turn back cooler so there is no hole, leave the airbox in and don't put the blow off valve back on. Get a decent exhaust that isn't too loud and you could even hide a bleed valve (I did). I also put a Power FC in and screwed the stock Nissan ECU faceplate on (tight fit but you can).
As I said, this time go smart and they wont get you, they never got me again :(
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934538
What did you do with the HC? Or do you not have one?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934578
Hand controller need not be connected all the time, and you don't really need it unless you're tuning on the side of the road...ala this guy:
http://www.youtube.com/watch?v=ojB7KkaR03I
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4934842
recently i got a canary for my exhaust, intercooler, bov etc.. i removed it all, patched the hole and is now stock..
is there a harsher punishment if i get dicked again with the same mods?
cheers,
mate 2nite i got the most fkn bullshit defect. exhaust too low, fair enough i dont mind getting it raised and a rwc. that would have cost me $60. instead he lists it as a major defect and a $300 fine. WTF? i was done 20+km over the speed limit and the fine was less that that. also, he didnt tick the RWC box. since when is height a major defect with such a fkn huge fine?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4936710
Its up to them to decide whether major or minor whether you get a fine or not and also whether you get points aswel, ive always gotten major defects and all with rwc, theve given me a major just for pod and rwc and fine, it depends on how much of a tight ass the cop is and yeah with the exhust being to low they love that on skylines always check that first , i got a major for being a couple of mm to low with a rwc like i said depends on the cop
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937609
I was under the impression that the law was "lowest part of the vehicle no lower than 100mm above the ground (maybe it's 90mm can't remember) so yeah it's a defect but Major, I suppose it depends how low it is
yeh i think hes just another of those racist f**ker cops. din bat an eye lid at all the holdens driving past over the limit with exhausts that sound like a fart in a milo tin but once he saw me he took off like a bat outta hell to catch me
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937613
not always, a lot of mods can be considering minor or major depending on the cop and the driver. major is usually safety wise, ie, bald tyres ect. major for too low is a dick move unless springs are cut. then its understandable.
Edited by Peter89
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4937934
Were you doing 20k over the limit when you were busted or are you saying the fine for doing 20k over the limit is less?
The defect is at Police digression, if they want to ream you they will. If they see previous offences etc they are more likely to ass f@*k you.
I didnt kno aftermarket ecu's were defectable..why is that?
Yes, it's due to emission laws. If you alter air/fuel etc then you change the emission's.
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4938626
Ohh,i didnt kno cops actually looked at them for defects,,lol dodgy dodgy..
but doesnt that make it illegal for apexi to sell pfc's or haltech to sell their units in australia?
https://www.sau.com.au/forums/topic/296128-f_ing-cops/#findComment-4942863
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
